ford sle 6640 gear problems
   / ford sle 6640 gear problems #1
graeme111
northern ireland
ford 6640 sle
hi.. i have a ford 6640 sle, the problem im having is to do with the gear changing.. the gears are confused,, if its in 4th gear it means its in 1st gear, and when its on 1st gear it means in in 4th,, as going down the gears 2nd and 3rd or ok.. also same problem with 5th till 8th gear,, can anyone help please?????////
   / ford sle 6640 gear problems #2
G'day and welcome the first thing to do is to check and clean all your earthing points and battery terminals also check charging rate as poor voltage can cause probs with these things.
Jon
Jon
thanks for this. i will get to it as soon as i can and see if it helps the problem.. many thanks
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2018 Trail King Lowboy (A56438)
2018 Trail King...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2018 FORD F-150 XL EXTENDED CAB TRUCK (A59823)
2018 FORD F-150 XL...
