Ford/NH 1920 electric meltdown! Can I use with no electrics?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #1
Lionhound
Scotland
Ford/New Holland 1920
Like it says, my 1920 had a meltdown. Major short caused total melt of the wiring at the ignition switch and smoke from the starter motor which I am now assuming is knackered. Quickest I can get a starter is 2 days but really need use of tractor urgently. To save having to hire is it possible to use tractor without electrics with a tow start? Would I have to connect ignition switch? If so, how?
Lot of questions for somebody new to this forum but need the help of your wisdom and knowledge.
Thanks in advance.
Rab
Update.
Ok, I removed the relay and put a bridge over 2 of the wires. Tractor started first turn.
All good I thought. Reconnected all electrics, put panels back on, turned key and.................!! well, engine turned and turned but wouldn't start. was like trying to start a tractor with the stopper still pulled out.
Any advice or solutions please?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #3
Sounds like your fuel solenoid valve is not opening. You should hear it 'click' when you turn on the ignition. If no click, you can apply 12 volts to the solenoid valve terminals with a 'jump box' or equivalent and then try to start. Ford New Holland Tractor Electric Fuel Shutoff - YouTube
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #4
That or you melted a safety cut out switch . You will probably be rewiring a tractor
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2021 Deere 331G (A53317)
2021 Deere 331G...
Margaritaville 5 O' Clock Somewhere Sign (A57454)
Margaritaville 5...
Misc Pallet of Toolbox, Welding Parts, and Torch Carrier (A57454)
Misc Pallet of...
2004 Chevrolet C5500 Flatbed Service Truck with crane, VIN # 1GBE5C1214F513547 (A57453)
2004 Chevrolet...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
