Ford/NH 1920 electric meltdown! Can I use with no electrics?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #1
Lionhound
Scotland
Ford/New Holland 1920
Like it says, my 1920 had a meltdown. Major short caused total melt of the wiring at the ignition switch and smoke from the starter motor which I am now assuming is knackered. Quickest I can get a starter is 2 days but really need use of tractor urgently. To save having to hire is it possible to use tractor without electrics with a tow start? Would I have to connect ignition switch? If so, how?
Lot of questions for somebody new to this forum but need the help of your wisdom and knowledge.
Thanks in advance.
Rab
Update.
Ok, I removed the relay and put a bridge over 2 of the wires. Tractor started first turn.
All good I thought. Reconnected all electrics, put panels back on, turned key and.................!! well, engine turned and turned but wouldn't start. was like trying to start a tractor with the stopper still pulled out.
Any advice or solutions please?
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #3
Sounds like your fuel solenoid valve is not opening. You should hear it 'click' when you turn on the ignition. If no click, you can apply 12 volts to the solenoid valve terminals with a 'jump box' or equivalent and then try to start. Ford New Holland Tractor Electric Fuel Shutoff - YouTube
   / Ford/NH 1920 electric meltdown! Can I use with no electrics? #4
That or you melted a safety cut out switch . You will probably be rewiring a tractor
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
Toro Zero Turn (A50324)
Toro Zero Turn...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
