CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more
Looked at this today to find:
Rob from Uppervalley advised all I needed was a socket to remove plugs... turns out you need to remove line from pump to injector for the front cylinder, the fitting that goes into the pump (and parts under spring tension can come out), and intake manifold for the other cylinders. I know this because I called Rick Wallace who looked at newer CK20S and older CK20 and told me CK20S you just remove the plugs and older CK20 requires the more extensive disassembly. Thanks for the info Rick.
If it really was just removing plugs, I'd tackle it, but I don't want to get into the fuel system related disassembly, intake, springs that come out of the rack and various other things that have to be removed given the plugs are buried making it impossible to get a socket on them. I don't want to risk introducing a fuel system problem.
- On the invoice it says under work to be done: remove and clean glow plugs
- It's obvious this wasn't done everything involved still completely dirty from normal dust from mowing -- there would be obvious evidence of all of the stuff that would have had to come off if the plugs were removed starting with spraying the threads on bus bar and plugs.
- Also obvious they didn't test starting it in the cold weather (machine was outside after the work done and below 20 degrees the days they had it -- if they tested it in the cold, the smart thing would have been to call me after filling their parking lot with smoke to tell me what's up and see about keeping it to fix the issue...)
In fairness to Upper Valley even though taking care of the glow plug problem was requested right on the invoice it doesn't look like they charged me for that work and didn't do the work... fine.
But it cost me more than 2 tanks of gas in the truck (rounded down to two tanks it's about $150 plus $685 for the work done and I bought a plug for $70.00 via mail thinking I could just install easily myself based info from Rob w/ 7mm wrench and 9mm socket).
Money spent: over $900
Time: 2 weekends of 1/2 day of hauling backing fourth each.
Glow issue solved: No.
It was made clear at the start there is a cold starting issue...
I would have much rather get the plugs replaced for a couple more labor hours / parts while the machine was there as it's going to cost me more now to haul it again...
In talking to Rick since changing plugs on pre CK20S tractors is a bit of work, he always does all 3. If Uppervalley made this recommendation to me I would have had them change all 3 even though only 1 is not functioning -- they are 9 years old w/ 6 years of use. With everything off to get one or more of them out, might as well change all 3.
Since the machine is stored inside for the winter and still functions I'll wait til after the mowing season to have someone fix it when it can be combined w/ regular service again.
Curious if you guys would be upset? I'm not happy about it... but I'm wondering what you guys think...
Unfortunately I can't state my overall experience was good...
Very happy with the work that was done, but unhappy the glow issue wasn't looked at when they had the machine. It's easy to ohm the plugs -- why didn't they do that? Why didn't they start it in the cold? Why didn't they execute what was requested on the invoice (remove and clean plugs is what Rob wrote on there -- they didn't do it or call me on that issue).
It it what it is... thought I'd share.
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #32
If it were my tractor I'd call Upper Valley and ask them why they did not do what was requested on the invoice. I'd also want to know what they did do and why. Then I'd see what they are willing to do for you to solve the cold start problem.
In future I'd find out what was actually done PRIOR to going to pick up the tractor by calling and asking them to verify item by item what work was performed.
One last point, you could mention to them that you have been posting your situation on TBN and will continue to do so until you feel satisfactory resolution to your issues has been accomplished. I would not use it as a threat so much as a heads up to your wanting the problem solved.
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #33
Hey Malk and everyone,
Looks like I am late to the party. Malk, I am sorry that you are having difficulty with a service we did on your tractor.
I am wondering why I received a private message on Jan 28th(first contact) when you have told everyone else on here about the problem before me as early as Jan 13th 15 days ago? You actually talked to another dealer before giving me a call?
I take great pride in our service and assure you that had you called me! on Jan 13th and expressed that you had a problem, it would have been handle in a day or two.
I am ALWAYS AVAILABLE to talk to any customer who has a beef. I will make this right as soon as I talk to Rob on Tuesday. Rob is not the person who did the service by the way. He will be the one to correct it, you have my word.
It sounds like this electrical problem has been an ongoing problem for you. As you know this is the first time we have worked on your tractor and may not have pursued the problem far enough once we thought the problem was in the key switch(very common).
I want everyone who deals with our dealership to know that if you have a problem, I take it very personally, and my guys know they will pay the consequences and make it right.
Please DO NOT leave a problem to fester this long without calling me first.
We are the only 3 year consecutive winner of Kioti 5 Paw in all of New England by making sure we do not have any unhappy customers.
Please call me at your convenience on Tuesday when I am back in the office so we can get this resolved.
Thanks to you all,
Dave G.
KiotiDave
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #34
Thanks to you all,
Dave G.
KiotiDave
I can't speak for the OP or why he contacted you by PM, but as the post above yours says, I have been trying to get the OP back on track with you regarding any issues he has with the recent service. I think sometimes owners feel this is the place to get advice on what to do next and sometimes the advice points them back to the dealer who is doing their service- and it is my belief that this is the right way to go...it gives you the dealer the chance to correct whatever is wrong, or work out a suitable solution, and it gives the OP the chance to regain a satisfactory relationship with their dealer. I don't know your dealership- but I've heard good things on TBN, and it makes sense to have you know what the op is experiencing so you can work on it together.
I'm confident you two will get things on track, and the OP will be able to report back regarding his satisfaction with your help.:)
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #35
:confused3:As this thread was expanding I was wondering why Dave was never mentioned as being in the loop.
Don
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #36
A restaurant owner I know once told me he wanted to hear customer complaints directly. His simple approach was "If you don't tell me something is wrong, how can I fix it?"
I think that same philosophy applies here as well and it sounds like Dave believes it too.
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #37
Hello Malk,
This is my second reply asking you to give me a call so I can take care of the starting problem you are having. I have replied to your private message from Monday when I first heard of this problem and left my contact info there as well. Unfortunately I do not visit this site very often so messages here will fall through the cracks.
I do not understand why you have not tried to talk with me? I can get your tractor fixed if I know you have a problem.
You need to call me and give me directions to your home and make the tractor accessible and your problem will be resolved.
Upper Valley Tractor and Equipment will always do right by our customers.
Dave G.
KiotiDave
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #38
Hello Malk,
Dave G.
KiotiDave
Well, You can't fix whats not in your shop. At least you tried..:)
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #39
Hello Malk,
Dave G.
KiotiDave
It,s good to see this kind of customer service these days.Keep up the good work.Malk315,maybe you can respond to the dealer who wants to help you with your problem?coobie
   / CK20 serviced at Upper Valley Swansea, NH no glow starting fixed and more #40
Looks like MALK315 took time to post in another thread yesterday but can't respond to Upper??? Looks like the dealer has taken giant steps to satisfy him. Does he just want to complain? Sounds like he has all the manuals too from his post in the other thread! So if he has all of that info he should have been able to figure out how to remove his glow plugs instead of complaining that someone at the dealer gave him the wrong advise.
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
2016 INTERNATIONAL PRO STAR TANDEM AXLE DAY CAB (A58017)
2016 INTERNATIONAL...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
Deere 310L (A53317)
Deere 310L (A53317)
