Ford NH 1320 Overfull crankcase/low Hydraulic
   / Ford NH 1320 Overfull crankcase/low Hydraulic #1
welder1
Is it possible for the hydraulic pump to divert fluid into the crankcase on this model? Did a search and saw this on other models. All help appreciated!
   / Ford NH 1320 Overfull crankcase/low Hydraulic #2
yes if the seal in the front of the hyd. pump goes out it will pump oil into the crankcase
Anyone tackled rebuilding the pump or replacing the seal? How hard of a job is it?
   / Ford NH 1320 Overfull crankcase/low Hydraulic #4
   / Ford NH 1320 Overfull crankcase/low Hydraulic #5
I'd also like to add that you need to find out why the pump shaft seal failed.
Was it just a wear issue and went? or was the pump deadheaded perhaps by a bad hyd valve, non operational relief or relief set to high.. or perhaps even a mis-seated quick disconnect.
on a positive displacement pump, it doesn't take much obstruction to pop a shaft seal.. oil has to go somewhere.
good luck on the issue. post back what you find.
soundguy
I bought this tractor used and it is a 1998 with only 115 hrs on it. I don't know how much it sat before I got it. I've pretty much put it through the ringer since i got it . I was hoping the seals may have gone bad from just setting inactive.
   / Ford NH 1320 Overfull crankcase/low Hydraulic #7
have you only used it a few minutes and it filled up quick.. or was it a few hours use with gradual fill up?
did 3pt or other remote hyds work normal?
if it was a slow leak.. it might simply be a tired seal. do check the shaft as well for damage or wear where the seal rides.
soundguy
It was a slow leak. Crankcase level looks to be a quart/quart 1/2 high. Hydraulic reservoir is barely showing on the dipstick. I last checked the fluids maybe 6 hrs run time ago and everything was OK. Lift worked normal. It will still raise my 5ft. bushhog at idle.
   / Ford NH 1320 Overfull crankcase/low Hydraulic #9
slow leaker then.. not a catastrophic dead head.
soundguy
I know it will cost me more(labor) but I'm thinking about just taking it to my local dealer and have them do it. I need to establish a good working relationship with those guys and this doesn't appear that it will break the bank.
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
