Ford F150-I'm Done.
/ Ford F150-I'm Done. #1
TheGoose
Veteran Member
SE Texas
Time to trade this POS off. Electric steering bad at 65K miles, several brake jobs, evap coil in the A/C out, seat torn at 50K, and now the brakes are locked up. Biggest pile of junk I ever owned. Loved the truck until it hit 50K miles and then it started falling apart. No more Ford for me.
BUILT FORD TOUGH = NOT TEXAS TOUGH.
Probably going to get a suburban.
/ Ford F150-I'm Done. #2
Well no more fords in my future anymore!. I like to know what the engineers thinking ?. I am replacing the back brakes and wheel cylinders also a brake line I didn't plan on but any way no more Fords.
/ Ford F150-I'm Done. #3
I am going with a 2500HD GMC gasser next time. I am not a fan of electric power steering, and not fond of electric fans for towing.
Was it an Eco boom?
/ Ford F150-I'm Done. #4
My 2006 F150 4X4 super crew cab 5.4 engine has not been the most dependable truck I have owned.One reason I went with 2016 dodge this time.I still have the ford but at 125,000 miles its starting to nickel & dime me.IMHO all brands have there share of issues just hope we get a good one not made on monday or friday.LOL..
/ Ford F150-I'm Done. #5
My 2012 F-150 just hit 60,000 miles and the only thing I've done so far is the brakes. I really didn't need to replace them, but we where planning a trip to Colorado and I thought i would be a good idea to have fresh brakes for the mountains. Biggest mistake I made was going with the more expensive, top of the line Wagoner brake pads. They went on super tight, which should have been a big warning right from the start.
The first day I drove it into town, about ten miles, it was raining and when I hit a water puddle, it turned to steam. I slowly made my way to a friends shop and had him take a look. They where so hot that they warped the calipers and caused over $400 in parts that had to be replaced. The manager of ABC Auto said that they had been having a huge issue with Wagoner pads and that they would reimburse me for the parts plus the labor to fix everything.
The problem with Wagoner brake pads is that they make them just a little thicker then factory, they use a metal in them that gets super hot and they cut the pads into different sized section that heat up faster in the small sections and remain hot longer.
A couple weeks later I went back to the store to pick up something and asked about my claim on the brake pads. The manager completely changed his story and denied telling me about all the problems they have had with Wagoner brake pads. My buddy who owns the repair shop couldn't believe it and called the manager himself, and was told the same thing. He never said anything about the brake pads and that they where the best ones out there.
Everything is now Ford brand parts, which seem to be trouble free and working flawlessly. Hopefully the truck lasts to 200,000 miles like the last two Fords did.
Whats wrong with the electric power steering?
/ Ford F150-I'm Done. #6
I'm curious about the steering issue as well?
/ Ford F150-I'm Done. #7
May I suggest a Toyota Tundra. Made in Texas! And Texas tough.
/ Ford F150-I'm Done. #8
I'd contact the manuf of the pads directly Eddie. Something is definitely wrong with those pads, and they should compensate you. If the store sold you the wrong pads (meaning, wrong PN), then a reputable manufacturer may "help them" understand that they need to do the right thing and step up.
I'm more familiar with the electric racks on small cars - at higher mileage they seem to wear out - meaning mechanical slop, and you can always have an electrical fault. The wear mechanism for hydraulic PS is mostly the seals, so long as you keep fluid in 'em, they keep running. New, I find the feel of many electric PS systems to be somewhat vague/less direct, but that is just personal preference.
Rgds, D.
/ Ford F150-I'm Done. #9
I always try use oem parts. Alot less headache. But what you were told sounds like bs. Wagoner pads have a good reputation. I would suspect that shop messed up.
/ Ford F150-I'm Done. #10
I installed the Wagoner pads and I took my truck to the shop after I realized there was a problem. Pads are very simple to install. When I brought it in and told them what I had done, the owner of the shop, a client and friend of mine, told me about all the issues he has had with Wagoner parts and that he no longer uses them. It was the owner of the shop that got the manager of the store to tell me about all the problems he had encountered selling them. Then later denied saying any of that to me, and then on the phone to my friend. My guess is that somebody at Wagoner, or up high at ABC explained to him that he better shut up and stop saying what he had been saying.
/ Ford F150-I'm Done. #11
I'm a bit curious about this as well. A thicker pad would simply mean the caliper plunger would have to be pushed back farther to install. Only way this would cause heat is if the caliper plunger is bottomed out and holding the pad tight against the rotor. Wouldn't that mean it was extremely difficult to install because there wasn't enough space between the two pad surfaces for the thickness of the caliper?
The various material types shouldn't create heat either. Usually most common complaint about various materials is that some squeal more when applied.
The cuts in the pad surface are there to help dissipate heat, similar to rotors that are grooved.
Would be interesting to take that Wagner number to a different parts store and see if they claim it's a fit for this particular truck?
/ Ford F150-I'm Done. #12
Very frustrating.
I accept errors as a possibility and have no grudge against admitting it and correcting it. When the story changes and nothing is done about the error, then I change vendors. :(
Eddie,
I had an almost identical experience with brake pads. Also, be aware that on the F150 one brake pad is slightly different from the other. One has a little hump, one does not. If not correctly installed it will rub.
To all who asked: The electric steering went out at 65K miles, Ford said "sorry, out of warranty". This is a truck that is bone stock, never been in high water etc. OK, chalk it up to bad luck. The repair was a little under $1800 but I paid $150 to have it towed to the dealer as it was unsafe to drive. Then the A/C went out. I charged it a few times until it would no longer hold a charge. Our winter has been extremely warm so I finally caved and got the A/C fixed. The evap coil under the dash (the expensive one) went out.
Spark plugs had to be changed out as well. I later found out that the ecoboost needs much more frequent spark plug changes. The fuel mileage has always been lower than advertised although the truck does have great power.
The truck is also making some kind of weird grinding noise when you turn sharply at low speed and today the brakes somehow locked up.
/ Ford F150-I'm Done. #14
I have a 2012 f150 with 87k. Front rotors trued up twice and on third set of pads. Rear rotors trued up once and on second set of pads. All work done at dealer some under warranty. This is more brake rehab than on any previous vehicle.
/ Ford F150-I'm Done. #15
My 2012 F150 has only had one repair on the fan blower motor controller @$80, a set of tires, and a battery.
89,000 miles of which its towed 7,000# to 10,000 about half of them.
You got a lemon!
/ Ford F150-I'm Done. #16
My friend has a brand new F-150 with the 2.7 Eco-Boost and it's eating engine oil. No one can figure it out. No leaks. it loses 4 litres every 5000 KM.
Like everything else made today....junk.
/ Ford F150-I'm Done. #17
I'm so "outdated". I'd never consider a 2.7L engine in a truck.....
/ Ford F150-I'm Done. #18
Probably the metal backing plate was too bit (top to bottom or front to back on the ears) and it was sticking in the bracket (vs retracting).
I have had to grind the ears on a pad down a few times when installing new brakes.
Aaron Z
/ Ford F150-I'm Done. #19
I've got a little over 90,000 miles with 40,000 miles towing (estimating in my head from my trailer towing miles on everything) and I'm still on my original brakes. My truck is a 2011 3.5L job ticket 2 truck.
Neggles are the electric compressor that Ford changed out in later years to eliminate but screws up so much that Ford quietly extended the warranty on it out to 150,000 miles.
I drilled a hole in the intercooler to keep the engine from swallowing slugs of water and hydro locking. Ford cannot do this because of the EPA, but all turbo used to have drain holes in their intercoolers for the same reason.
The engine has two known problems that are now resolved in the 2017 redesign of the entire engine. The first is timing chain stretch that is $3000 buck you will not get back when it happens and the second is the high pressure fuel pump seal failing and dumping gas right into the oil pan.
Other than these things the truck has been pretty good.
/ Ford F150-I'm Done. #20
My 2012 has 180k miles on it, it runs like a top other than a small noise in the rear end.
