Ford E150 P2197 Check Engine Light
/ Ford E150 P2197 Check Engine Light #1
OKnewguy
Platinum Member
Edmond, Oklahoma (OKC)
Jinma 224
Hey gang, I posted back a while ago trying to trouble shoot, a p2197 code on my 2004 Ford e150. P2197 is o2 bank 2 sensor 1, so I installed an o2 sensor in the front on the passenger side. Back before I replaced the sensor I would occasionally get a p0153 (slow response bank 2 sensor one).
So anyway, the truck was good for 150 miles or so, and then tripped the 2197. I have put 200 to 300 miles on it since it tripped and it did not throw any other codes. Currently I have plenty of time and would like to try and trouble shot this myself, I do have a good mechanic, but he is expensive.
What would be the next course of action?
Thanks, Dave
/ Ford E150 P2197 Check Engine Light #2
My Saturn had the same issues. It was tripping the 02 sensor code. I don't remember it being as sophisticated as your Ford, 1 code and 2 sensors, not 2 different codes for 2 different sensors. Anyway the gas mileage went from 31 to around 17 so I had to do something. I changed both sensors 1 at a time with no results. It ended up being a very expensive catalytic converter. Take it to a good muffler shop and have them look at the exhaust system. It is usually a free estimate and inspection.
Chris
Thanks for the suggestion. So far the mileage seems normal. I guess the closed loop program is pretty decent. This sensor should be pre-cat. So I do not think that the exhaust stuff should effect it. I will verify it this afternoon.
Thanks, Dave
/ Ford E150 P2197 Check Engine Light #4
I would think the cat could still give a code on a pre cat sensor due to backup of pressure or a comparison between the pre and post cat sensor. I think what happened on mine before and after changing both sensors was the difference between the two sensors was out of max spec so it trips the code...
Chris
/ Ford E150 P2197 Check Engine Light #5
I am not sure how your van is set up and the only one I have ever messed with is the Saturn I own. Its a 4 cylinder so only 2 sensors. Does yours have a set of sensors for each side of the V8 engine? If so could you swap them and see if the problem follows the sensor?
Chris
Yes, there are 2 sensors for each side. bank 1 is supposed to be drivers side (with sensor one being pre cat, and sensor 2 post cat), and then bank 2 being passenger side. I did replace with a new o2 sensor. But I will see if I can swap around, I think they actually have different connectors. My Chilton manual recomends testing for the voltage for the heater in the o2 wiring harness. I might see if I can cannibalize some kind of plug so I can take readings.
Dave
/ Ford E150 P2197 Check Engine Light #7
If you can switch the sensors from one bank to the other it would rule out the sensor being bad. Twice I have replaced 02 sensors in different vehicles and got a bad one which threw the same code, I exchanged it and all was well. I assume you are unhooking the battery and taping the brake a few times before replacing the sensor so the ECU will reset any and all codes too.
/ Ford E150 P2197 Check Engine Light #8
Dave
You might want to check your source for info. Bank 1 is passenger side and bank 2 is drivers
/ Ford E150 P2197 Check Engine Light #9
Dave
Hey OKnewguy, didn't I tell you which bank is which back in November? :D
/ Ford E150 P2197 Check Engine Light #10
good job Dmace, I didn't know you already told him. Based on his comments I gathered he got the info from Chiltons and they aren't always on the mark.
Another thing he should pay close attention to is the 02 connector condition, look at both halves! Any signs of corrosion are suspect and need to be corrected. These sensors rely on minuscule voltage changes ie...spizzwinks as we call them:D...and the slightest bit of resitance change can play havoc with OBD2 test results
OH Man!!!!!!! How bad is it when you start a thread specifically asking were something is, or how to whatever, and then you screw things up anyway. I feel like a complete morooooooon. I did install it in the wrong bank!!!!!!!! This is actually VERY good, hopefully this will really fix things now. Please excuse the my goof up!
Thanks everyone!!!!!, Dave
P.S. I'll let everyone know how it turns out.
/ Ford E150 P2197 Check Engine Light #12
One thing I have learned over the years is never assume a part you buy from the local auto parts store is good. You can get a bad one from time to time and if you are a methodical trouble shooter like me it can drive you crazy.
I have replaced parts in a logical order before assuming everything I bought was good only to come full circle and find out the first part I bought was a bad one.
Sometimes the best way is to "borrow" parts from a buddy with a like vehicle just to isolate problems. Also, a lot of parts have electrical or vacuum trouble shooting you can do on the bench. Most people won't take the time to do this.
I agree with you 100%. I recently replaced an alternator, I used one of the remans from Napa. I have usually had good luck with Napa, but this thing was completely dead. It was no trouble to swap it out, but still an inconvience.
BTW, I swapped O2 positions and cleared the code, and I have about 45 miles with out the CEL coming on!
Thanks gang, Dave
Well we are now around 200miles or so. Lets hope it keeps it up.
Thanks, Dave
ALUMINUM HYDRAULIC TANK (A68842)
ALUMINUM HYDRAULIC...
2013 WACKER NEUSON  LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
CAT 320 CL GP Bucket (A68134)
CAT 320 CL GP...
ALLMAND  MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
84" Smooth Shell Kit (A68134)
84" Smooth Shell...
