Ford Bronco back by 2020
   / Ford Bronco back by 2020 #61
So it sounds like the Bronco will be a U.S. version of the Ford Everest. 4 doors only. Built to compete with Jeep. Getting back to Ford's roots, since they designed the famous Jeep grill and headlights during the government contracts in the beginning.
That thing looks like a warmed over Escape. No thanks. Make the one that the concept was based on.
   / Ford Bronco back by 2020 #62
Tractor tire truck 067.jpgA few more
   / Ford Bronco back by 2020 #63
   / Ford Bronco back by 2020 #64
AGRIMAN, is that an Atlas T-case?
I believe you are what us Rednecks here in Missouri call "Rock Bouncers". Love it!!! :)
   / Ford Bronco back by 2020 #65
I'm not sure there is a "Concept", only some artist's dream. :)
   / Ford Bronco back by 2020 #66
I'm not famillar with the Atlas T, but the SCS seems to be a different animal. They are built for high HP
and torgue loads. They are also changeable gear and dang near indestructible. They are use in monster trucks, pullers and mud trucks. I'm sure someone has a crawler with a SCS case.
Check out their site. I'm going to read up on the Atlas T. It's a nice looking case. Do you much experience with them?
You got me, I have no idea what a Rock Bouncer is... LOL.
4x4 Transfer Cases for Performance Cars & Trucks | SCS Gearbox Inc
   / Ford Bronco back by 2020 #67
A Rock bouncer is a four wheel drive buggy with a high horsepower engine that drives up a slope that you can't hardly walk up without a rope and they have enough horsepower that the whole buggy bounces up and down as the tires get traction and lose traction.
Often, they will load water into at least the front tires if not all four tires to get the center of gravity down lower so that they are less likely to flip over backwards and go tumbling down the hill. They will also generally run what they call stickies which are a tire with a very soft compound so that it kind of sticks to the rock. They will usually have over built drive trains to handle the shock loads when the tires get traction otherwise they would shred their axles, driveshafts, transfer cases, etc.
Aaron Z
   / Ford Bronco back by 2020 #68
Aaron Z
Oh, ok sorry. I have never heard them called bouncers. I have always heard them called crawlers.
   / Ford Bronco back by 2020 #69
A rock crawler is usually driven at a lower speed, it is usually somebody driving down the trail and crawling over rocks with friends (and winching up if they can't make it) vs an event where the drivers take turns going up a particular or course (often racing against the clock).
In other words with rock bouncing your sponsor is paying for your broken parts and with rock crawling you're paying for your broken parts.
Rock bouncing:
Aaron Z
Xtreme XR1045 (A50120)
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
4-27x10.5-15 Hauler Skidloader Tires & Rims (A50774)
4-27x10.5-15...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
