gstrom99
Veteran Member
- Joined
- Nov 4, 2015
- Messages
- 2,469
- Location
- Greene, Iowa
- Tractor
- Deere 855, Deere 530R zero turn, Allis Chalmers D17 III, Polaris Ranger, Deere 3032E (SIL's), Yamaha Timberwolf 250, Husky saws, H & H 10k and Carry-On trailers
TSC sells the correct fluid.I am glad you said something... Finally getting around to doing this. I pulled the drain plugs, first water, then milkshake!
Reading some other threads, guys cleaned it out with kerosene through the observation plate. My dad wondered if running regular ATF through it would flush it out before running the correct stuff. In my reading, use the common Universal Tractor Hydraulic Fluid? Thanks
Look at / replace the gearshift rubber boot. Even if not real cracked, any rain that hits there, will drop into the trans/hyd oil. Reach in and scrape out the built up gunk on the bottom of the case.
