Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run
I'm voting for the key switch being the culprit.
I did replace it 2 or 3 years ago with what I thought was a good quality toggle switch but maybe it wasn't.
   / Ford 9N intermittent spark, won't run #23
That's about how long the good ones are good for, a marine rated switch is the only one I have found that lasts for any reasonable length of time.
   / Ford 9N intermittent spark, won't run #27
Pretty good chance the engine has been replaced. Can you read the serial number on the block? If so, does that number indicate a 1939 tractor?
   / Ford 9N intermittent spark, won't run #28
9N 1320
Randomly clicking through the pics on the 9N registry shows all of them with right mounted generator like mine.
9N & 2N Ford Tractor Registry
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
J-BAR SD5 5' ROTARY MOWER (A51243)
J-BAR SD5 5'...
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2023 Ford F-150...
