Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run
I'm voting for the key switch being the culprit.
I did replace it 2 or 3 years ago with what I thought was a good quality toggle switch but maybe it wasn't.
   / Ford 9N intermittent spark, won't run #23
That's about how long the good ones are good for, a marine rated switch is the only one I have found that lasts for any reasonable length of time.
   / Ford 9N intermittent spark, won't run #27
Pretty good chance the engine has been replaced. Can you read the serial number on the block? If so, does that number indicate a 1939 tractor?
   / Ford 9N intermittent spark, won't run #28
9N 1320
Randomly clicking through the pics on the 9N registry shows all of them with right mounted generator like mine.
9N & 2N Ford Tractor Registry
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
7021 (A50322)
7021 (A50322)
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2001 TOYOTA 7FCGU25 FORKLIFT (A51222)
2001 TOYOTA...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2008 PETERBILT 335 DAY CAB (A51222)
2008 PETERBILT 335...
