Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run #33
Only one version was available from TISCO for years. That's all I sold and so far as I know the mount was the only difference between the two part numbers.
I got that resistor on Amazon but it did not come with 2 sets of screws as advertised, it came with one set that was too small and was metric. The terminal posts were also metric and larger than the originals. So I had to drill out the mounting holes, use a dremel tool to move them farther apart, counter sink them, and grind down the heads of the original screws so I could reuse them. Then I had to change the ring terminals on some of my wires because they wouldn't fit on the new posts. At least the resistor works and solved my spark issue, hopefully it lasts.
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52128)
NEW 2022 Load...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
2013 John Deere 160G LC Excavator (RIDE AND DRIVE) (A50774)
2013 John Deere...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
