Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run
   / Ford 9N intermittent spark, won't run #33
Only one version was available from TISCO for years. That's all I sold and so far as I know the mount was the only difference between the two part numbers.
I got that resistor on Amazon but it did not come with 2 sets of screws as advertised, it came with one set that was too small and was metric. The terminal posts were also metric and larger than the originals. So I had to drill out the mounting holes, use a dremel tool to move them farther apart, counter sink them, and grind down the heads of the original screws so I could reuse them. Then I had to change the ring terminals on some of my wires because they wouldn't fit on the new posts. At least the resistor works and solved my spark issue, hopefully it lasts.
Ford NAA Jubilee Tractor (A52128)
Ford NAA Jubilee...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2020 CF Moto 500 Trail (A50514)
2020 CF Moto 500...
400 bu Gravity Wagon (A50514)
400 bu Gravity...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
