Ford 8N
/ Ford 8N #1
bigbill61
240 Massey Ferguson
Need a starter solenoid for a 1952 FORD 8N. Sits on top of starter and is 6 volt. This is for My uncle who has macular degeneratin. He hooked wires up backwards and fried the solenoid. Any help locating one would be greatly appreciated.
/ Ford 8N #3
Rry NAPA. 8N parts are fairly easy to come by, especially electrical parts. Make sure you take the old solenoid with you so you get the correct one. I believe it has three terminals.
/ Ford 8N
Thanks. Got one on order from ford8n.com.
/ Ford 8N #6
i'm surprised hooking up the wires backwards did ANYTHING.
it won't even energize if the bat and starter connections are reversed...
IE.. I'm not sure of a way to damage it hooking it up wrong.
double check the solenoid.
lil terminal goes toward block and gets GROUND fromt he thumb switch.. starter connection is the transfer bar, and bat connection is the wire from bat hot (-)
soundguy
/ Ford 8N #7
soundguy
My feelings exactly. I don't see how a reversed solenoid would hurt anything.
/ Ford 8N #8
actually.. it can't...
the coil simply would not energize.
2010 FORD RANGER SINGLE CAB PICKUP TRUCK (A59912)
2010 FORD RANGER...
Lot of Allmand Light Plant Fixtures - Halide Assemblies (Bulk Lot) (A63689)
Lot of Allmand...
2021 JCB 35Z-1 Mini Excavator (A61572)
2021 JCB 35Z-1...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
KUBOTA X1140 RTV (A63291)
KUBOTA X1140 RTV...
