Ford 8N
/ Ford 8N #1
bigbill61
240 Massey Ferguson
Need a starter solenoid for a 1952 FORD 8N. Sits on top of starter and is 6 volt. This is for My uncle who has macular degeneratin. He hooked wires up backwards and fried the solenoid. Any help locating one would be greatly appreciated.
/ Ford 8N #3
Rry NAPA. 8N parts are fairly easy to come by, especially electrical parts. Make sure you take the old solenoid with you so you get the correct one. I believe it has three terminals.
/ Ford 8N
Thanks. Got one on order from ford8n.com.
/ Ford 8N #6
i'm surprised hooking up the wires backwards did ANYTHING.
it won't even energize if the bat and starter connections are reversed...
IE.. I'm not sure of a way to damage it hooking it up wrong.
double check the solenoid.
lil terminal goes toward block and gets GROUND fromt he thumb switch.. starter connection is the transfer bar, and bat connection is the wire from bat hot (-)
soundguy
/ Ford 8N #7
soundguy
My feelings exactly. I don't see how a reversed solenoid would hurt anything.
/ Ford 8N #8
actually.. it can't...
the coil simply would not energize.
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
Timpte 720 All Aluminum 7000 Tilt Trailer (A63689)
Timpte 720 All...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
Toro Greenspro 1260 Towable Greens Roller (A56859)
Toro Greenspro...
