Ford 8n with front mount distributor
/ Ford 8n with front mount distributor #1
Jlsmith80
Kokomo, In
76 troybuilt horse 50 massey 22
My 8n was running rough replaced coil worked for a while then would not start. Pulled offdistributor to check points. Points where not opening. Replaced points distributor cap rotor. Installed distributor and still wouldn"t start. I am getting 6 volts to coil but no spark to plugs what now. Any ideas.
/ Ford 8n with front mount distributor #2
Idiotic questions when you most likely controlled the opening of the new ponits? Have you tried switching capacitor? If you have then I tried to look at the opening of the plugs, if that's all right then it's time to consider a new coil
/ Ford 8n with front mount distributor #3
he just put a new coil on.
quit changing parts.
recheck points gap.
if you have bat voltage to top ov the coil then points are open.
