Ford 8N or similar older types
   / Ford 8N or similar older types #41
I think it will be tough to find any of those even in half-decent condition for $6000 at least here in our area!
ITs not about finding them in that price range......its simply about finding them at all.... Which is what is so compelling about the 8n. They are EVERYWHERE.
Within 1000 miles.....tractor house lists a whole whopping 7 ford 1710's for sale. I can probably fine 7 N-series tractors for sale just in my county :ROFLMAO:
   / Ford 8N or similar older types #42
Sure I agree.
I meant all of these models you mentioned in your post:
"Ford 10-series like a 1710.....something like a deere 750/850/950/1050, Massey 230"
That covers quite a few different models but not for $6000 ...
   / Ford 8N or similar older types #43
Sure I agree.
Not sure where the OP lives. So without knowing that.....cannot say. But Im gonna stand by my statement that they can be found in the $6000 range.
Here is a 1720
A 1910
A 750
An 850
A 950
A massey 231
   / Ford 8N or similar older types #44
Nice thread on old tractors. I notice a couple of things....
1. A suprising amount of tractor guys have an 50 + year old tractor that they plan to keep.
2. They also have a more modern 4wd compact tractor- usually with a loader.
   / Ford 8N or similar older types #45
There is a logical reason for that. In spite of what many believe, there actually are a few jobs that can be done more effectively with a 70 year old, 2wd, manual steer, non-loader equipped, gear trandmission gasser than a modern CUT.
Two that I can think of right off the bat, is operating my 2 x 12 plow, and my 2-row corn planter. My modern, 4wd CUT, lacks hydraulic draft control, so unless mud is an issue, I will always pick the old 8n for use on that. It certainly don't hurt that that is the implement that tractor was designed around.
The little corn planter is also much easier to use on that low platform, quiet, easy on/off from either side, antique Ford than it is with my modern, significantly larger CUT. The loader joystick prevents access from the right side on that, and it is over a foot higher to get on and off. It also takes a lot longer to attach the planter, because it is heavier and the clearance to the hitch pins is tighter.
Having a modern 4wd, diesel with a loader is handy, but having an antique in addition makes a lot of sense. That loader just blocks your view and takes up space for many jobs. It is great to have a tractor with one, and another without one.
It is almost a crime to destroy the near perfect balance of a Ford n by putting a loader on one. That is really the only reason I have 2 tractors. If i didn't need a loader for lots of jobs, i could get by fine with just the 1951 8n. One more big plus of the modern 4wd tractor is that it is far superior on a disk, saving lots of money on fuel. When it comes to the plow or planter though, I will take the antique most every time.
   / Ford 8N or similar older types #46
May I add one .... the ability to adjust the wheel track width, both rear and Front, to match the the row or plow width. Particularly if you have spin-out rims on the rear.
   / Ford 8N or similar older types #47
The new compact tractors are a good way to go & they are emission exempt if a diesel 25 or less horse power no regen required or def & the torque is awesome along with power at the PTO & you pretty much need 4wd if you get one with a FEL & the weight of the tractor is another factor & on my M-F 1526 with a 3 cylinder Iseki engine is a proven power plant & they don't need a turbo , & they are easy on fuel consumption. They are as close as you can get to the older utility tractors & the newer one without all the problems previously mentioned of a bigger diesel engine.& on my 61 year old M-f 50 I like the the gasoline engine at 34 HP & that it's a 2 speed high low manual transmission making it 6 forward & 2 reverse & being gear driven you can start off in any range you want & with the newer hydrostatic tranmission your speed range is limited when working in 4wd & using the FEL . But these 2 tractors working together compliment each other on what they can do & can't do & both tractors work year round & both have there assignments & 2 tractors are better than one when it comes to not having switch out implements for different task & yes I know about the quick connects But we are beholding to the weather & I don't want to rely on a weather man who gets it 50/50 most the time & as far as the old & the new tractor I'll keep them both, after all there a work saver.
   / Ford 8N or similar older types #48
You can buy a lot more tractor for $6k than an 8N... Won't have a loader but an 8N won't either (at least not a useful one). For a tractor that you're actually going to use I wouldn't even look at an 8N 'type' tractor. I've spent some time both using them and working on them, you couldn't pay me to own one.
I bought a 60 hp 4wd diesel for $4500 in January, I've seen people asking that much for their 8N... Look at 1980's era tractors (Massey Ferguson, Ford, etc...).
   / Ford 8N or similar older types #49
I fit what you say to a tee. I use my modern 4wd Branson compact tractor with loader 90% of the time. My old Ferguson TO35 (standard diesel) still gets used to pull the manure spreader, fertilize with the cone fertilizer spreader, and is used for harrowing. I completely overhauled my standard diesel about 12 years ago and was able to find every part except cam bearings without much problem. It is a little hard to start when cold, but if one knows the tricks it isn't that bad.
   / Ford 8N or similar older types #50
Looking at the hour meters and maintenence records on my modern, loader-eqquied CUT, and my 70 year old 8n, it appears that usage had been just about evenly split over the last 5 years. I also got rid of a couple other, less frequently used antique tractors, the last couple years, so those two now get all the work.
I used to have plenty of storage space, but a couple old barns, that my great great grandad built, have fallen into disrepair. I can only keep what fits in my new pole barn. It was also taking me too much time to keep all those tractors maintained.
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
1781 (A58375)
1781 (A58375)
