Ford 8N dribbling coolant out of radiator overflow, not overfilled.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #1
BossofBBQ
1950 Ford 8N
Hello everyone, first time poster, long time reader.
I am the proud owner of a new-to-me 1950 Ford 8N tractor. Upon purchase, I did the usual maintenance: fresh fluids/filters, new 180 degree tstat, and a new fan belt.
The problem is that once it reaches operating temp, there is a steady dribble of coolant leaking from the radiator overflow tube. I read the 75 tips, and only added enough coolant to just barely cover the core. After about an hour of running, it dribbles out maybe a quart, after that, it stops. This is leaving the core completely exposed once everything cools down.
I have no signs of coolant in the oil, or oil in the coolant. If I add a quart of water to bring it back up to a “proper” level, it just leaks out again. Furthermore, there is no compression in the cooling system that I can tell. No bubbles in coolant, I can cover the radiator fill neck with my hand without feeling compression rushing out.
The belt is properly tensioned for 1/2” of play. I added a temp gauge just before the tstat in the upper rad hose, and the tractor operates within normal temp range, stabilizing around 195-200 degrees f.
Apologies for the long-winded first post, but I’m stumped on this one. Any advice is much appreciated. Thanks in advance!
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #2
Welcome aboard!
Sounds like a bad cap to me.
Cooling systems only work right under pressure- heat expands the fluid. A bad cap won’t make the pressure necessary. That pressure also keeps the coolant from boiling.
I’ve always filled about 1/2 way between the top of of the fins and the cap, seems to work fine for me. Dunno if it’s right or wrong or indifferent.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #3
Bad Cap Seal?
Is 200 typical for that year?
Most of my older rolling stock is in the 160-180 range…
Did have an old Ford with a head gasket going bad and another with a new water pump that was puking water… I made the impeller a little smaller drilling a hole in each vane and cured the problem.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #4
Since you have tried checking for compression and are not over filling the radiator, which is usually the problem, I will have to go along with it being the radiator cap. They are a cheap and easy fix to try.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #5
The factory cap spec is 4 psi if memory serves. I would get a new one from my local Napa.
Thanks for the replies everyone! I’ll put a new 4 PSI cap on and see if it fixes my issue.
Ultrarunner- the factory N-series thermostat was 160*, IIRC that would result in a normal operating temp of 160-180.
I was told that a hotter 180 degree thermostat would get the oil hot enough to boil off condensation, leading to a cleaner engine (which runs hotter.)
I may end up reverting back to OEM 160*, but am not sure yet.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #7
I'd stick with the 160 t/stat. My old 9N had a non-pressurized (read zero psi) system. Not sure if the 8N is any different.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #8
Ford started using a pressurized radiator mid-year for the '43 2N. It was 4 psi.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #9
I would stay with the 180 thermostat if your use of the tractor is usually short run times (an hour or less), now if you are running it for hours at a time then the 160 would be fine.
   / Ford 8N dribbling coolant out of radiator overflow, not overfilled. #10
If you can put in a coolant recovery bottle and make sure the cap has a top and bottom rubber seal, it should stay full, just like the new stuff does.
2008 Dodge Avenger Sedan (A53424)
2008 Dodge Avenger...
Tires (A50322)
Tires (A50322)
ASSORTED NYLON SLINGS (A54757)
ASSORTED NYLON...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
