ford 850 hydraulic problems
/ ford 850 hydraulic problems #1
oldmanlance
kentucky
1958 850,ford,tc 40 newholand
having problems with shuttering or jumping when going up
/ ford 850 hydraulic problems #2
Thats usually a tell-tale sign of air in the system, o-rings on both ends of the piping coming up to the pump or the shaft seal in the pump itself. With engine running slow, loosen the bleed plug on top of pump just until oil starts coming out (not too much or it will blow the plug out and you'll get a hyd. oil bath) let it seep for a few seconds, tighten and see if the lift works smoother.
/ ford 850 hydraulic problems #3
It does sound like air in the cylinder, Have you done anything or changed anything? Also go to a place where you can go fully down and up with the loader arms to remove air.
i fixed the leaks it had ,put a kit in the pump ,it looked real good . thanks i may need to bleed the air out some more. you also have raise the lever more than half way to the top for it to raise.
/ ford 850 hydraulic problems #5
G'day don't forget to check the oil level i know it sounds obvious but sometimes we can't see the forest for the trees !!:)
/ ford 850 hydraulic problems #6
cam follower pin and cam.
jittering pump can be pistons../ valves. etc..
soundguy
NEW HOLLAND 355 FEED MILL (A64277)
NEW HOLLAND 355...
Loudo Trailers 20ft. T/A Utility Trailer (A64557)
Loudo Trailers...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
90in. Work Bench (A65640)
90in. Work Bench...
