Ford 850 Hyd problems
/ Ford 850 Hyd problems #31
I put a dime on this plug for a pressure gauge...If you dont have a 5000psi gauge, just open plug up a few turns, leave a few threads, just crank a few turns on the starter, to check if there is high pressure coming/spraying out....if no pressure, run 3p up to stop (max pressure) then there should be pressure....
Ditto what mikes tractor said.. wrong plug.. and running the lift up doesn't make max pressure.
according to the manual, if you want to test the pressure, you chain the upper lift arms to the axle trumpets, then operate the lift... the pressure on the gauge on the #3 plug should show relief pressure..
soundguy
/ Ford 850 Hyd problems #32
#17 plug sprays? or #3
soundguy
/ Ford 850 Hyd problems #34
let us know when you do.
soundguy
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2005 GMC C4500 (A60462)
2005 GMC C4500...
2018 Chevrolet Traverse SUV (A60352)
2018 Chevrolet...
iDrive TDS-2010H...
BBI PT 20' Litter Spreader (A60462)
BBI PT 20' Litter...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
