ford 845 diesel?
   / ford 845 diesel? #1
solarkowboy
tilly arkansas
ford 845
just bought what the former owner owner said is an 845 ford tractor. can't find any info on this model with diesel engine. any info?
   / ford 845 diesel? #4
Look for the model number on the left side of the tractor on the flat surface above and behind the starter. If it is a 4 speed, what you will find is model 841.
8= utility wide front tractor with 172 cid engine
4= 4 speed
1= 1958 - 1962
   / ford 845 diesel?
thanks. its a 4 speed. is that a diesel configuration?
   / ford 845 diesel? #6
After 1958 diesel was an option. Yours should say 841-D. The D suffix is for diesel. Check it out and post back what you find. I bet the previous owner just thought the 1 looked like a 5 (easy to do). The only two numbers that could be in that column are 0 or 1. 0 means 57 or older, and diesel wasn't available until 58.
   / ford 845 diesel? #7
Welcome to the forum from Oklahoma.
Ken
   / ford 845 diesel? #10
WELCOME to TBN :)
I moved your thread to the New Holland Owning/Operating Forum.
2018 CATERPILLAR 299D2 SKID STEER (A51246)
2018 CATERPILLAR...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2008 Lincoln Electric Ranger 250GXT Trailer-Mounted Welder (A51691)
2008 Lincoln...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
