ford 845 diesel?
   / ford 845 diesel? #1
solarkowboy
tilly arkansas
ford 845
just bought what the former owner owner said is an 845 ford tractor. can't find any info on this model with diesel engine. any info?
   / ford 845 diesel? #4
Look for the model number on the left side of the tractor on the flat surface above and behind the starter. If it is a 4 speed, what you will find is model 841.
8= utility wide front tractor with 172 cid engine
4= 4 speed
1= 1958 - 1962
   / ford 845 diesel?
thanks. its a 4 speed. is that a diesel configuration?
   / ford 845 diesel? #6
After 1958 diesel was an option. Yours should say 841-D. The D suffix is for diesel. Check it out and post back what you find. I bet the previous owner just thought the 1 looked like a 5 (easy to do). The only two numbers that could be in that column are 0 or 1. 0 means 57 or older, and diesel wasn't available until 58.
   / ford 845 diesel? #7
Welcome to the forum from Oklahoma.
Ken
   / ford 845 diesel? #10
WELCOME to TBN :)
I moved your thread to the New Holland Owning/Operating Forum.
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
