ford 845 diesel?
   / ford 845 diesel? #1
solarkowboy
tilly arkansas
ford 845
just bought what the former owner owner said is an 845 ford tractor. can't find any info on this model with diesel engine. any info?
   / ford 845 diesel? #4
Look for the model number on the left side of the tractor on the flat surface above and behind the starter. If it is a 4 speed, what you will find is model 841.
8= utility wide front tractor with 172 cid engine
4= 4 speed
1= 1958 - 1962
   / ford 845 diesel?
thanks. its a 4 speed. is that a diesel configuration?
   / ford 845 diesel? #6
After 1958 diesel was an option. Yours should say 841-D. The D suffix is for diesel. Check it out and post back what you find. I bet the previous owner just thought the 1 looked like a 5 (easy to do). The only two numbers that could be in that column are 0 or 1. 0 means 57 or older, and diesel wasn't available until 58.
   / ford 845 diesel? #7
Welcome to the forum from Oklahoma.
Ken
   / ford 845 diesel? #10
WELCOME to TBN :)
I moved your thread to the New Holland Owning/Operating Forum.
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
WOODS DHS48N LOT IDENTIFIER 72 (A53084)
WOODS DHS48N LOT...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
