Ford 841 electronic ignition
   / Ford 841 electronic ignition #1
mayer2323
Want to convert to electronic ignition from points . Have just bought kit . Has anyone done this to a 6 volt positive ground system ? Would like some advice. Thanks
   / Ford 841 electronic ignition #2
Reports I have read from knowledgable folks say that 6 volt electronic ignitions are more problematic than 12 volt setups. Voltage drop while cranking is apparently more of a problem, and instead of weak spark as one would have with breaker points, there simply is no spark at all. Make sure your battery cables, battery, and starter are completely up to snuff. As with all electronic ignitions, be absolutely certain your battery polarity matches the requirements of your kit.
   / Ford 841 electronic ignition #3
where you buy the kit
   / Ford 841 electronic ignition #4
Google is your friend. Pertronix makes the most widely available & popular EI kits. Available throughout the US.
If you are in Goshen, CT, I'm about an hour away and can help.
pineplainstractor.com
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2025 New/Unused Wolverine Clip on Pallet Forks (A51573)
2025 New/Unused...
FAKE (A52472)
FAKE (A52472)
