Ford 841 electronic ignition
   / Ford 841 electronic ignition #1
mayer2323
Want to convert to electronic ignition from points . Have just bought kit . Has anyone done this to a 6 volt positive ground system ? Would like some advice. Thanks
   / Ford 841 electronic ignition #2
Reports I have read from knowledgable folks say that 6 volt electronic ignitions are more problematic than 12 volt setups. Voltage drop while cranking is apparently more of a problem, and instead of weak spark as one would have with breaker points, there simply is no spark at all. Make sure your battery cables, battery, and starter are completely up to snuff. As with all electronic ignitions, be absolutely certain your battery polarity matches the requirements of your kit.
   / Ford 841 electronic ignition #3
where you buy the kit
   / Ford 841 electronic ignition #4
Google is your friend. Pertronix makes the most widely available & popular EI kits. Available throughout the US.
If you are in Goshen, CT, I'm about an hour away and can help.
pineplainstractor.com
28013 (A50322)
28013 (A50322)
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
2024 JOHN DEERE 6110M LOT NUMBER 267 (A53084)
2024 JOHN DEERE...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
