Ford 7740 ?
/ Ford 7740 ? #1
Decexcav
Ford 7740 SLE
How do you remove the radio from 7740 ford tractor and can you replace it with a regular Car radio?
/ Ford 7740 ? #2
Not sure how to remove the radio since I don't know your tractor model well enough but usually you remove the trim piece that surrounds the radio and then you might need special key tools to remove the specific brand or just start removing screws that hold the bracket in. As long as the tractor has 12 volt ( which I believe yours does) you can replace with any 12 volt car radio.
Hope this helps!!
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
Walnut Slabs (A65640)
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
Skid Steer Rotary Cutter (A65640)
Skid Steer Rotary...
