Ford 7740 ?
/ Ford 7740 ? #1
Decexcav
Ford 7740 SLE
How do you remove the radio from 7740 ford tractor and can you replace it with a regular Car radio?
/ Ford 7740 ? #2
Not sure how to remove the radio since I don't know your tractor model well enough but usually you remove the trim piece that surrounds the radio and then you might need special key tools to remove the specific brand or just start removing screws that hold the bracket in. As long as the tractor has 12 volt ( which I believe yours does) you can replace with any 12 volt car radio.
Hope this helps!!
New/Unused Receiver Hitch (A61166)
New/Unused...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
1999 John Deere 310E Loader Backhoe (A61567)
1999 John Deere...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A61567)
2006 John Deere...
1998 JOHN DEERE 120 EXCAVATOR (A62129)
1998 JOHN DEERE...
