Ford 6700 pto problem
/ Ford 6700 pto problem #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
New pto clutch & new control valve was installed several yrs ago but pto was only used a few times then tractor was used as a dedicated tractor to pull a wheel rake. Now after being attached to JD 467 rd baler pto started slipping after baling 8 rd bales. Same rd baler was used last year on a Kubota M7040 & JD 4255. Hyd filter was changed on 6700 before attaching to baler. I advised tractor owner to get a hyd gauge & check to determine if hyd pressure is close to 2100 psi.
Thanks in advance for any ideas, Jim
/ Ford 6700 pto problem #2
I would be more interested in pressure to PTO/dual power circuit than main hydraulics. Different pump section and different circuit entirely. Should be at least 150 PSI. 160 - 180 is expected.
Thank you for your reply. I agree with you since I've given this more thought. Can you direct me where to view parts diagram to view hyd/pto pump on NH parts site? I've looked under heading of hyd's & trans & can't locate the pump.
/ Ford 6700 pto problem #4
I just went through this on my tractor. I found a lot of the pump stuff in the engine section.
2024 Kubota L47 T.L.B. 94HRS FOR SALE loaded w/options & $17K off new at $63,900!
2024 Kubota L47...
Vanguard V215-PH 4WD Articulating Heavy Haul Agricultural Tractor (A66734)
Vanguard V215-PH...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
WELDING TABLE WITH VISE (A68842)
WELDING TABLE WITH...
