Ford 6700 pto problem
/ Ford 6700 pto problem #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
New pto clutch & new control valve was installed several yrs ago but pto was only used a few times then tractor was used as a dedicated tractor to pull a wheel rake. Now after being attached to JD 467 rd baler pto started slipping after baling 8 rd bales. Same rd baler was used last year on a Kubota M7040 & JD 4255. Hyd filter was changed on 6700 before attaching to baler. I advised tractor owner to get a hyd gauge & check to determine if hyd pressure is close to 2100 psi.
Thanks in advance for any ideas, Jim
/ Ford 6700 pto problem #2
I would be more interested in pressure to PTO/dual power circuit than main hydraulics. Different pump section and different circuit entirely. Should be at least 150 PSI. 160 - 180 is expected.
Thank you for your reply. I agree with you since I've given this more thought. Can you direct me where to view parts diagram to view hyd/pto pump on NH parts site? I've looked under heading of hyd's & trans & can't locate the pump.
/ Ford 6700 pto problem #4
I just went through this on my tractor. I found a lot of the pump stuff in the engine section.
2022 EZ-GO ELITE...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
2015 John Deere 8270R (A64119)
2015 John Deere...
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
