Ford 6610 getting hot
   / Ford 6610 getting hot #1
Mr Blue
Totnes
I have recently purchased a 1984 6610. I used it yesterday to do some grassing cutting with a 8 foot topper did the job well, but when I finished I noticed that the rear axle was really hot, is this normal or do I have a problem ?
   / Ford 6610 getting hot #2
Make sure your remote valve levers are in the neutral position and not stuck in the raise or lower position.
Gary
   / Ford 6610 getting hot #3
The brake wasn't left on was it? That'll heat up the rear end in a hurry.
Thanks guys for your replies, but remote valve levers were in the neutral position and the handbrake was not on. Any other ideas ?
   / Ford 6610 getting hot #5
Handbrake?
   / Ford 6610 getting hot #6
What do you mean by "hot". It's normal for the rear axle fluid to get warm just due to inefficiencies in the gear train and the hydraulic pump.
It is not the oil that is getting hot but the metal work. I could not keep my hand on the rear axle because it was so hot. I called my wife over and she could smell the heat coming off it as she got close !
   / Ford 6610 getting hot #8
Maybe a brake is stuck?
   / Ford 6610 getting hot #9
Or a bad bearing. I would vote of brake dragging internally. Might take it out naked and do 20-30 180 degree turns and some breaking in reverse. The tractor may have set a lot.
   / Ford 6610 getting hot #10
Is the hyd. oil cooler working?
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
GENIE MAN LIFT (A52472)
GENIE MAN LIFT...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2014 FORD F-550 SUPER DUTY SERVICE TRUCK (A52472)
2014 FORD F-550...
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
