Ford 641 Workmaster Questions and Advice
   / Ford 641 Workmaster Questions and Advice #51
i have no idea what 'yellow bucket oil'
is.
rear most drain is diffy.
up from that is hyds.. up from that is trans.. up from that is crankcase.
you CAN put UTF meeting ford/nh spec M2C134 in the aft 3 sumps. or put utf in the hyds sump, and a 80w90 gear oil in the trans and diffy.
hyds holds, nominally, 2 gallons.. has a dipstick to check. CAN hold alot more if needed for external hyds.
rear end has a check level plug onthe left axle trumpet side about even with the pto.. it's a pip plug. fill till it dribbles there.
trans is fileld and there is a level check plug on right side about where your heel is , just above the running board. it's on t he trans.. not center section.. so look at the seam between the 2, and lknow which you are looking at. it's a plug.. not a fine thread bolt.
   / Ford 641 Workmaster Questions and Advice #52
I want to thank everyone especially Sound Guy for the help on my 641, everything is just as you've said except there is no dipstick for Hd. Also I discovered a lever on the right side below the seat on the casing any idea what this is for? I'm trying to bring this 641 back after it was obviously abused by previous owner, fluid changes were so long overdue I couldn't believe the fluid I drained. Again thanks for the help. Any help I can give on anything home repair related please don't anyone hesitate to ask. I am liking this 641 more every time I use it. Thanks Melvin
   / Ford 641 Workmaster Questions and Advice #53
when it left the factory it had a dipstick for the hyds.
it was right next to the pto engage lever aft of your left heel. it's a round, flattened button style cap. right next to pto shifter in same round cover.
the lil lever by the 3pt control is the draft control. up for position.. ( horizontal ).. down for draft.
   / Ford 641 Workmaster Questions and Advice #54
Hi everyone,
I am new to the site. Does anyone know if Ford made a 641 Workmaster with a 172ci engine? My tractors serial number says its a 1961 and right above that is 841-L. the hood and grill do not look like an 841 powrmaster, they look like the 641 workmaster. any help figuring out excatly what i have would be appriciated.
   / Ford 641 Workmaster Questions and Advice #55
Dave, welcome to the site. It's considered good form to start your own thread when you ask a new question. I'm sure you'll get an answer, especially if you post a pic or three of your rig.
Jim
   / Ford 641 Workmaster Questions and Advice #56
Dave is it a four or five speed. 1962 was the last red/gray ones sold so I guess anything is possible. Is the 841 number on the bell housing/transmission area. I am almost certain that part was make for an 800 based on on we had.
   / Ford 641 Workmaster Questions and Advice #57
These are some pics of my tractor with the serial number.
   / Ford 641 Workmaster Questions and Advice #58
It's a four speed tractor. The numbers are on the left side, right behind the starter on the transmission case.
   / Ford 641 Workmaster Questions and Advice #59
Thanks for the response Gale. I have attached some pics.
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
2015 Ford F-350 4x4 Pickup Truck (A54814)
2015 Ford F-350...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
2020 DRAGON ESP...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
