Ford 5610 External Services Problem
/ Ford 5610 External Services Problem #1
Harold Bishop
My 5610 seems to operate the three point link without a problem and can easily lift heavy attachments. Its the hydraulics from the spool valves that are getting weaker all the time. ie, front loader is now getting weak. Any ideas ? Also, how to do a home test and home fix ?
/ Ford 5610 External Services Problem #2
Welcome to TBN:D
Are the 3PH and the loader run from the same hydraulic pump?
Testing is simple, you need to buy a gauge (less than $20.00) and test your pressure at the loader-with that info you can further diagnose the problem.
John Deere 5103 (A53317)
John Deere 5103...
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2014 Ford Focus Sedan (A59231)
2014 Ford Focus...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
