ford 545 backhoe
/ ford 545 backhoe #1
anninlahonda
la honda,ca
1981 ford 545 backhoe
I need help!!how does the starter work on this 1981 machine ?
/ ford 545 backhoe #2
could you perhaps post a bit mor einfo.. or actually state the problem you are having? so far we know you are having some issue with the starter.. is it not engaging with the key? or are you actually asking for an explanation of how the starter functions.. IE.. spinning and bendix/drive gear.. etc...??
/ ford 545 backhoe
I'm sorry .I need to find out how the fuel gets switched on and off is it electrically thereare two connections on the injector pump what do they do?Thankyou for your patience
/ ford 545 backhoe #4
if you see wires to a solenoid on the back of the IP they are almost deffinately a fuel stop solenoid for key/off operations.
follow your fuel line from tank to IP..
I'm not familiar with that machine.. but it should be clear what it goes thru.. IE.. electric fuel pump, mechanicl lift pump, and or sediment or water seperators and filter heads.
post back what you find.
/ ford 545 backhoe #5
ps... this new of a machine question is likely better handled by user RickB or Whodat. I'm an 'old' ford guy.. if it's late 70's it's kinda 'new' to me.. :)
if it was made while we were putting the man on the moon.. I'm on it.. :)
/ ford 545 backhoe
Thanks I'll let you know after I see my friend tonight.
ATS 60 Gallon 2 Stage Air Compressor (A62679)
ATS 60 Gallon 2...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
Corner Posts (A65640)
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59914)
2006 STERLING...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
203201 (A60429)
203201 (A60429)
