Ford 5000 with 3 cyl diesel? D5011P
   / Ford 5000 with 3 cyl diesel? D5011P #1
somanytractors
atlanta, ga
several
I've got a ford D5011F with a 3 cylinder diesel in it.
I cant find anything on a 5000 with a 3 cylinder.
Did they make them with a 3 cylinder or did someone put something else in it?
The numbers on the bell housing are correct. I'm not sure where to look for numbers on the engine itself.
The motor is froze so I'll need at least gaskets and rings for it.
After posting I googled D5011F and the 4500 came up which has a 3 cylinder diesel in it. Is this a 4500?
Thanks for any help :)
John
   / Ford 5000 with 3 cyl diesel? D5011P #2
I googled Ford 5011 and found an old post on yesterday’s tractor stating this has a 4000 engine, 5000 frame to make it a heavy frame for back hoe loader work.
If this correct then you would have 3 cylinders
   / Ford 5000 with 3 cyl diesel? D5011P #3
A 4500 has a steering system similar to an early 5000. The transmission and rear axle are sized for the 4000 series.
   / Ford 5000 with 3 cyl diesel? D5011P #4
D5011F is a 4500
D50 = 4500 industrial 1965-75
1 = Diesel
1 = no PTO
F = 4x4 torque converter auto reversing Transmission
Thanks everyone for the help. Its good to know what I'm working on.
   / Ford 5000 with 3 cyl diesel? D5011P #6
John
I had a '79 4600 with the 4.4x 4.4 3 cyl engine...205 or thereabouts cu. in.. Every 5000 or above of the series has a 4 cyl that I know of.
John Deere 96020R Tractor (A53342)
John Deere 96020R...
Electric Mobility Scooter (A51694)
Electric Mobility...
BUSH HOG 7007 LOT NUMBER 116 (A53084)
BUSH HOG 7007 LOT...
2023 LMC M40018 LOT NUMBER 176 (A53084)
2023 LMC M40018...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
