Ford 5000 with 3 cyl diesel? D5011P
   / Ford 5000 with 3 cyl diesel? D5011P #1
somanytractors
atlanta, ga
several
I've got a ford D5011F with a 3 cylinder diesel in it.
I cant find anything on a 5000 with a 3 cylinder.
Did they make them with a 3 cylinder or did someone put something else in it?
The numbers on the bell housing are correct. I'm not sure where to look for numbers on the engine itself.
The motor is froze so I'll need at least gaskets and rings for it.
After posting I googled D5011F and the 4500 came up which has a 3 cylinder diesel in it. Is this a 4500?
Thanks for any help :)
John
   / Ford 5000 with 3 cyl diesel? D5011P #2
I googled Ford 5011 and found an old post on yesterday’s tractor stating this has a 4000 engine, 5000 frame to make it a heavy frame for back hoe loader work.
If this correct then you would have 3 cylinders
   / Ford 5000 with 3 cyl diesel? D5011P #3
A 4500 has a steering system similar to an early 5000. The transmission and rear axle are sized for the 4000 series.
   / Ford 5000 with 3 cyl diesel? D5011P #4
D5011F is a 4500
D50 = 4500 industrial 1965-75
1 = Diesel
1 = no PTO
F = 4x4 torque converter auto reversing Transmission
Thanks everyone for the help. Its good to know what I'm working on.
   / Ford 5000 with 3 cyl diesel? D5011P #6
John
I had a '79 4600 with the 4.4x 4.4 3 cyl engine...205 or thereabouts cu. in.. Every 5000 or above of the series has a 4 cyl that I know of.
IH 470 Disk (A50515)
2013 John Deere 544K Articulated Wheel Loader (A50322)
2013 John Deere...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
197359 (A50458)
197359 (A50458)
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
