OregonFord5000
- Joined
- Mar 29, 2021
- Messages
- 8
- Tractor
- 1969 Ford 5000
So long story short, after hydro fluid gets hot running my 6-disk new Holland mower, the pto has a real hard time starting back up after I shut it off. Sometimes I have to give a little help by twisting the driveline. Yep, a real pain when you're trying to get hay cut. So I pressure tested the hydro pressure for the Pto per the 70's Era set of Ford service manuals I have. Manual says 130-165 psi at an idle when warmed up. I had about 50 psi (give or take). Does this sound like a main hydraulic pump issue (tractor doesn't have any problem with heavy 3-point implements) or possibly something else causing the drop in pressure? I have everything stripped off the top and the lift cover ready to come off so I can check the clutch and all. Just wondering if I may have to get to the pump and I'm not totally sure where that is at. Knowing my luck it isn't under that top cover. Thanks!
