Ford 4610 engine slight miss?
   / Ford 4610 engine slight miss? #11
111549.jpg The Napa kit will get you the basics, but you'll need the adapter in the middle pictured in the following kit.95279.jpg Toolsource #: 95279 Manufacturers #: 34800 Also known as:
SGT-34800. Can't find similar in Napa, but both are online at Toolsource.
Awesome. Thank you very much.
I have it on order now and look forward to giving it a try. Really think I have a burnt valve or other issue as power seems down recently. The strange part is that in cold weather it still cranks almost instantly.
Guys so I'm back working on this tractor but have still not found a resolution yet. First off it's actually a 4600 not a 4610 but still same 201 Diesel engine. We have now adjusted valves which were found to be in spec. We have done a compression test on all 3 cylinders. All are were well in spec per Ford specifications. Injectors were replaced. Fuel filter replaced. Timing was found to be advanced to 7 or so. Apparently someone has been monkeying with it in the past as Ford spec says to start at 0. Seems have more power and smoke less now but the vibration still exist between 1600-1800. Also we put in new fuel shut off valve in fuel tank. So now I'm out of ideas. Anyone have any thoughts as to what could be causing the issue? Also it's engine related as it does it in gear or out of gear. Causes stuff to shake and vibrate badly on the tractor and is very annoying. Thank you
   / Ford 4610 engine slight miss? #15
Did you check for bent push rods while adjusting the valves or check lift? Did the pistons have full travel? It might be worth dropping the oil pan and checking for a bent rod.
What's the history on the "miss"? Was it like this when you got it? Did the engine ever hydro-lock?
I didn't check the rods yet. As for the history it ran smooth I thought when I bought it a couple years back. Then one day I noticed the vibration in 1600-1800 range. It overheated briefly one time as the radiator was low but can't remember if vibration started before or after that. Lastly what is hydrolock? Thank you
   / Ford 4610 engine slight miss? #17
Hydrolock is any type of liquid puddling on top of a piston. Piston cannot complete compression stroke because of foreign material. Something usually bends.
Ok none of that happened as far as I know. Could something be wrong with the fuel pump?
   / Ford 4610 engine slight miss? #19
Thanks for the info. I did just change the fuel filter to see but no change with new one
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2005 UD Truck UD1300 Landscape Dump Truck (A56858)
2005 UD Truck...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Electric Golf Cart (A56859)
Electric Golf Cart...
