Ford 4400
   / Ford 4400 #1
Lazyacres
Woodbury, TN
Kubota m8200 4x4
I have a 4400 that has a blue belly and yellow top. It has a loader. I am trying to find information about this tractor. Part of the serial number is missing.
   / Ford 4400 #2
A 4400 is a variant of a 3 cylinder 4000. The unit code will be more helpful than the serial number. Both, plus the model code, are found on the foil tag on the underside of the hinged half of the hood as well as hand stamped on the RH side of the clutch housing.
   / Ford 4400
Thanks. Is there any way to identify the model loader that is on it?
   / Ford 4400 #4
A Ford loader had a tag on the inside of the loader boom above or below the bend where the bucket tilt cylinders' base end mount. Might still be there. It is most likely a 735 if it is a full-frame Ford loader with crankshaft driven pump.
71057 (A49346)
71057 (A49346)
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2014 VOLVO VHD DAYCAB (INOPERABLE) (A50854)
2014 VOLVO VHD...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
Informational Lot - Shipping (A51039)
Informational Lot...
2021 ALLIANCE NORTH AMERICA, INC AIRMAN SDG45 GENERATOR (A50854)
2021 ALLIANCE...
