Ford 4400 restore
   / Ford 4400 restore
Those are good old tractors for sure, I love my 1968 4500. My whole steering system was shot so I converted it to full hydraulic and gutted the steering gearbox and linkage.
Awesome, That looks great! Do you have a build/repair thread? If not, could you tell us where you got the parts? If your able, A few more pictures would be greatly appreciate too. The front end on mine is completely shot too. I'm thinking I'll spend more money and time trying to fix whats there instead of just ripping/replacing it. Were you able to use the power steering pump for pressure or did you tap in to the tractor hydraulics?
   / Ford 4400 restore
Hawkeye, I bet your right on the fuel shut off solenoid. Mine doesn't have one but I might consider putting one. Sometimes I forget to shut the fuel off when I'm done using it and it will leak out the carb. The previous owner put an electric fuel pump on mine. I'll be removing it because it runs fine without it.
   / Ford 4400 restore #13
Got it back together enough to test starting and no spark so I am going to try changing coil first then go from there.
If you are going to just throw parts at it instead of diagnose it.. as you are doing now. i sugest you sell it and buy a new tractor and save yourself some headaches.
I bet over half the ignition coils sold for old tractors were never .. ever needed.
I have a HUGE fleet of old gassers. I have probably bought ----***** 5 *****---- replacement ignition coils ever...
do some testing.
could be points.. especialyl if it has been setting.
get a real test lamp. many times VOM are not the best for checking power in a kettering ignition system.
VOM has very high input impeadance... too high to be usefull.
   / Ford 4400 restore #14
Dont know where I was that I missed the thread but nice project indeed.
IF I could have found a ford in the 4000-series for near scrap price, I would be working on one of them instead of the 300u I am now.
Those axle trumpets are big cause of the inboard breaks.
Paint is cheap (but time consuming). While you are having it appart, I'd give her a coat of paint. BAsically what I am doing with the 300U. Replacing whatever seals and o-rings that leak, inspecting everything else, paint, and re-assemble. My goal is tight and no leaks. But if you dont clean it up and paint it, If you do sell it, it will look like a leaker for sure.
   / Ford 4400 restore #15
Hey Davo727, that is a very interesting conversion. Wouldn't mind doing that myself. I have a question though, "How much did that cost?" If your tractor is a gas would you mind sending a pic of the system from the tank to the carb? Thanks.
   / Ford 4400 restore #16
City, I think I am going to take that solenoid out and put a mechanical valve in. Simpler. Is your 4400 a 6v or 12v? Generator or Alternator? If alternator did you install?
   / Ford 4400 restore #17
Here is the steering conversion http://www.mytractorforum.com/showthread.php?t=211740 The parts that I used are listed in the 4th message , not the ones in the first message. Prices: steering valve $343, column $94, actuator cylinder $160. Had all the hydraulic hoses made up at Hufco in Conroe Tx, they are the Parker Hydraulic store here.
I used the power steering pump on the engine and it works fantastic.
   / Ford 4400 restore #18
Couple more pics
   / Ford 4400 restore
Thank you Davo! I'll be doing the same thing. I really appreciate all of your and everyone else's input. From what I gather you recommend using a 7" cylinder instead of the 8", right? Were you able to fit the cowl back on without to much trouble?
   / Ford 4400 restore #20
Yes on this industrial front axle 7 inches travel is what it needs, you want to get close to the stops but not hit the stops with cylinder travel left or you will break the stop or break the spindle. I would recommend asking Bailey Hydraulic online if they will make you up a 7 inch travel cylinder using the one I used as the starting point.
The cowl fit fine, I did have to fold over the rear seam on the gas tank though. If you use a little longer steering column then you could make your steering valve mount shorter so the valve is lower and it would give you a little more room than mine.
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
