Ford 4000
/ Ford 4000 #1
Philbilly
Ford 4000 & MF 265
Could someone tell mr where I can find instructions on how to replace a brake rod seal.
/ Ford 4000 #2
take and disconect the brake rod from the brake pedal under the running board then remove the adjustment nut thats is on the end of the rod and then take a flat head screw driver and get under the lip of the on seal and prise it out sometimes u will have to drive the srew drive under the lip which is on the out side of the housing then do in reverse to put back to gether it is a pretty simple job once u have done it once
/ Ford 4000
Thanks a bunch, since I don't know what year the old tractor is, I'll just take the old seal to the parts house for a replacement.
/ Ford 4000
Maybe you can tell me what these numbers mean.
/ Ford 4000 #5
u have to get the numbers off the to of the bell housing behind where the starter bolts on but the part number is all the part numbers is for the same seal
86576339,
C5NN2N336A,
E7NN2N336AA,
85999093
/ Ford 4000
Finally got around to getting the numbers.
They are;
M4000
7J01B
A157312
Maybe you can tell mr what they mean.
Thanks
/ Ford 4000
whodat526 said:
built in atwerp belguim
1967 model
and it is a 4000 ford
Man, you're on the ball, I appreciate all the usefull info.
/ Ford 4000 #10
G'day those seals are avail aftermarket but they are nowhere near the quality of the N/H ones we have tried a few over the years and have not had much success with them. Also to fit them bak into the housing i use a big socket that fits on the outside of the seal ( 3/4 drive so the rod goes through ) and a spacer or 2, flat washer and wind it in with the nut on the brake rod. Good luck with it:thumbsup:
Jon
/ Ford 4000
Thanks for the info.....
/ Ford 4000
Could someone tell me how much fluid to put in brake drum of 67 ford 4000.
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
1999 INTERNATIONAL 4700 4X2 FLATBED DOVETAIL TRUCK (A65057)
1999 INTERNATIONAL...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
