Ford 4000 pouring diesel (I think) from a strange place...
   / Ford 4000 pouring diesel (I think) from a strange place... #41
Strange the clutch wasn't affected - it would have to be soaked with the level of the leak, wouldn't it? That amount of oil and water would slip the driven disk under any load. Must be a good disc in there.
Jim
   / Ford 4000 pouring diesel (I think) from a strange place... #42
i've seen bellhousings soo full of oil it was coning out under the steering box!
   / Ford 4000 pouring diesel (I think) from a strange place... #43
Jim
actually.. wet clutches don't slip so much.. but may grab a bit.. or swell.
remember.. many devices actually USE oil imersed clutches for long life. IE. independent pto packs are usually wet disc.
Folks, I hit a snag in trying to drain the tranny... Went and tried to open the drain plug on the Trans using a open end wrench, and the square bolt stripped like butter. I tried a pair of big vice grips, and no luck. Next step is maybe a small pipe wrench? Any suggestions on breaking the puppy loose? Torch it? There has to be a magic trick of some sort to get this drain plug out...
-- I don't have access to a welder to weld a hex bolt to it.... Found one of your posts, great suggestion, if you have a welder....
   / Ford 4000 pouring diesel (I think) from a strange place... #46
I'm thinking a big VG would be a better choice than a Pwrench, unless you've got enough bolt head to work with.
Big VG really tight, plus about 3' of pipe on the end ? Hands in a position such that you don't punch something that doesn't move, if you manage to break the VG loose, or in half.
Heat on the bolt is usually a good idea.... if there's water in the sump, those threads may be a bit scuzzy. Even a propane torch can be enough to do the trick.
If that doesn't work, try pounding on an almost-fits impact socket, and using your longest breaker bar plus pipe extender.
Rgds, D.
Thanks, will try all the above till something works. A friend of mine offered to let me borrow his cracker box, so if all else fails I will try Sound's suggestion (from another post) of welding a hex over the old stripped out head.
   / Ford 4000 pouring diesel (I think) from a strange place... #48
Hit it with a hammer, not hard enough to break anything, but it can kind of loosen it a little. Then try turning it slightly tighter before trying to loosen it (I know it sounds crazy, but it works!) And yes, if you can heat it a some, do so.
   / Ford 4000 pouring diesel (I think) from a strange place... #49
It has a tapered thread, no sealing surface other than the threads. It may be enhanced with some thread sealing/locking product, so I would attack it with heat. Putting a nut over the stump and weld would be my choice, that make concentrated heat and a new head.
   / Ford 4000 pouring diesel (I think) from a strange place... #50
How bug is the plug?
Usually ford uses some rather large plugs. Like 1-1/2" NPT that have a ~1" or bigger square.
If thats the case those big iron plugs usually arent machined and not real tight on the tolerances for the wrench. And open end wrenches are "springy". I like a good 15" crescent wrench on them. but if already rounded, the damage may be done. I'd opt for a pipe wrench next. Vice grips are worthless IMO
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52576)
2018 FREIGHTLINER...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
