FORD 4000 Not Charging
   / FORD 4000 Not Charging #31
If it is a a/c alternator I would put my money on diode fail. The diode is "leaking" to ground and makes a circut thru the bulb .
   / FORD 4000 Not Charging #32
Ended up replacing the voltage regulator ..... again... all good now
Thank you for the information
   / FORD 4000 Not Charging #33
since you own the vreg now anyway. take the cap off and see if the cutout contact is sticking.
   / FORD 4000 Not Charging #34
we have been talking about GENERATOR.. not ALTERNATOR
   / FORD 4000 Not Charging #35
i bet you had a sticking field and cutout contact. lucas regs are BAD about that.
sometimes the fields get welded with improper polerization.. or faults from the genny field.
if you hav ethe old one.. take the cap off for a looksee. sometimes sticking points can be popped apart.. polished.. and then saved as emergency spares..
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2016 Ford Explorer...
Kubota RTV500 (A47384)
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
2013 DRAGON  130BBL VACUUM TRAILER (A50854)
2013 DRAGON...
