Ford 4000 boiling over.
   / Ford 4000 boiling over. #21
while you're at it, flush the engine block too.
   / Ford 4000 boiling over. #22
How do I go about flushing the engine block? I've heard this was a good thing to do for sure. I am somewhat confident that's blocked up because I have a hard time filling the tractor to capacity with coolant. It always seems a couple quarts short.
   / Ford 4000 boiling over. #23
garden hose, and top and bottom hoses removed.
if you want to get fancy, can remove core plugs :)
   / Ford 4000 boiling over. #24
Thanks for all the advice! (And sorry for the cross-posting)
I ordered a brand new radiator, water pump, hoses, etc. Hopefully by this weekend I'll have them installed, and the block flushed.
Is it worth getting a compression tester from auto-zone to check for a cracked head?
   / Ford 4000 boiling over. #25
it MAY be, if the problem persists.. though most places lend tools cheaply or free anyway.. so.... :)
   / Ford 4000 boiling over. #27
Fixed the problem! No broken head, no bunk radiator, no shot water pump. Just a loose fan / alternator belt that needed to be adjusted!
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
Kubota L2501D (A50120)
Spool of Wire (A47384)
UNUSED FUTURE 4 GAUGE 25' JUMPER CABLES (A51243)
UNUSED FUTURE 4...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
John Deere 7130 (A50120)
John Deere 7130...
