Ford 4000 boiling over.
   / Ford 4000 boiling over. #21
while you're at it, flush the engine block too.
   / Ford 4000 boiling over. #22
How do I go about flushing the engine block? I've heard this was a good thing to do for sure. I am somewhat confident that's blocked up because I have a hard time filling the tractor to capacity with coolant. It always seems a couple quarts short.
   / Ford 4000 boiling over. #23
garden hose, and top and bottom hoses removed.
if you want to get fancy, can remove core plugs :)
   / Ford 4000 boiling over. #24
Thanks for all the advice! (And sorry for the cross-posting)
I ordered a brand new radiator, water pump, hoses, etc. Hopefully by this weekend I'll have them installed, and the block flushed.
Is it worth getting a compression tester from auto-zone to check for a cracked head?
   / Ford 4000 boiling over. #25
it MAY be, if the problem persists.. though most places lend tools cheaply or free anyway.. so.... :)
   / Ford 4000 boiling over. #27
Fixed the problem! No broken head, no bunk radiator, no shot water pump. Just a loose fan / alternator belt that needed to be adjusted!
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
TEST BID LOT (A50775)
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
Year: 2020 Make: Cadillac Model: Escalade Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 73,021 (A50324)
Year: 2020 Make...
