Ford 3930 steering
/ Ford 3930 steering #1
ajm555
Danville
Ford 3930
Tractor starts out fine, but as it warms up the power steering begins to fade and eventually quits. Changing the filter and flushing made no difference. Steering will work approx. 45 minutes before begins to fade. Any ideas to correct the problem??????
Replace the pump or can it be re-built ?
So, replace the pump and hope that's it. Thanks.
/ Ford 3930 steering #4
Browsing the forum I see nobody seems to want to know about your problem AJM. Maybe 'cos the site looks pretty 'orange' orientated at times.
Anyway, you could have been a little more forthcoming with information.
How old is the Blue Beast? How many hours? - 45 mins - warms up...? How hard do you work it in the 45 mins? How hot does it get? Objective or subjective analysis: Do you measure temps to determine heat? If so, where and with what? Hand, Thermometer, Digital Thermometer...?
When the steering fades away, do any hydraulic functions fade as well? FEL & 3PH still work?
Regularly serviced? Last oil/filters changed when?
You see, it's hard to help you when you didn't help us much. Clairvoyance is not a diagnostic tool in my box.
Good luck with your pump change. Report back if you can.
1999----unkn hours---normal maneuvering----operating temp, tractor not overheating---
When the steering fades away, do any hydraulic functions fade as well? FEL & 3PH still work? --------------steering is only part malfunctioning
Regularly serviced? Last oil/filters changed when? serviced regularly ----- new filter installed has no effect
Now that you have all this information does it change your ability to answer the question????
/ Ford 3930 steering #6
Yes it does! But I have no in-depth knowledge of the Ford 3930 but I think the pump sits on the LHS under the alternator? My point being, you see how you had all this info before-hand to add to your original query?
Hydraulic components involved are:
Pump. Is it leaking or weeping at all? What oil did you put in the reservoir when you changed it?
Is the
Steering orbital. Any leaks or sloppy feel at the wheel?
Steering Ram. Leaks externally? Any noises at full lock? (Possible internal leakage?)
Pump rebuild is viable. they are similar to the MF pump and most older car Power Steering Pumps.
Someone else here may have had a similar issue so stand by.
And don't be so grumpy! Just trying to help. :)
/ Ford 3930 steering #7
Use the search function, there's been hundreds of these "hydraulics don't work or weak hydraulics" threads before. Unless you put a gauge on the pump pressure port (working & not working) there isn't any "good" advice besides replacing/rebuilding parts until it's fixed.
Once you Isolate the problem, pump, steering valve or the steering cylinders, only then can somebody give some "good" advice.
2009 International 4300 Box Truck 24' (A62613)
2009 International...
Luck Now XLR 4750ST (A64126)
Luck Now XLR...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
1000 Gal Fuel Tank w/ Electric Pump (A64127)
1000 Gal Fuel Tank...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59914)
2025 PJ CC162 T/A...
