Ford 3910
/ Ford 3910 #1
richlahmers
ford 3910
my Ford 3910 sat all summer with a new battery(spring 2011) & now it won't even start to turn over! Checked battery & it was holding 12.47 volts! It ran fine when I put it away! I'm lost!!!
/ Ford 3910 #2
Did you clean the terminals? Its possible its corroded or one of the terminals isn't making good contact.
/ Ford 3910
yes I cleaned the terminals, also the dash & the headlights work! That's why I'm confused!?!
/ Ford 3910 #4
check to make sure the high low lever is in neutral there is a safety switch on that lever and you might try wriggling it while trying to crank it
/ Ford 3910 #5
rich: Have you tried to jump it with other tractor/truck with known good battery? My tn had the same problem, would just click starter. Checked voltage, and it looked good. Jumped it and it would charge up slightly, and then maybe start 1 time. wouldn't next. New battery cured problem. :thumbsup:
2011 PETERBILT 386 (A67714)
2011 PETERBILT 386...
GENERAC MOBILE PRODUCTS  MAGNUM LIGHT/WATER PLANT (INOPERABLE) (A67714)
GENERAC MOBILE...
Year: 2018 Make: GMC Model: Terrain Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 116,222 Pla... (A66738)
Year: 2018 Make...
2016 CHEVROLET SILVERADO 2500HD (A67714)
2016 CHEVROLET...
2021 Kubota BX2680 25HP 4WD Utility Loader Tractor w/ Attachments and 2021 T/A Flatbed Trailer (A66734)
2021 Kubota BX2680...
2015 CHEVROLET SILVERADO CREW CAB PICKUP TRUCK (A66091)
2015 CHEVROLET...
