Buying Advice Ford 3600, what do you think?
   / Ford 3600, what do you think? #11
if it's a pto seal only.. it's about 20$ for a new seal and gasket.
make sure it is not a bad bearing... with machine off.. grab shaft and see if there is in / out movement or side play. if none.. it's a realitively easy fix.. just make sure pto engagement is 'in gear' before you slide her out... and tip nose down to prevent loosing oil.
it's about a 6 m job to pull the 4 bolts, slip the shaft out, pop out split rings.. drop bearing carier off shaft/bearing.. drive out seal... seat new seal.. lube.. clean carrier, reset shadt and split rings.. clean gasket surface, add gasket, stab hole and slide home. put in 4 bolts.
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
SPRAY TRAILER (A58214)
LOT: (9) Tires & Rims: 275/80 R22.5, 275/70 R22.5 and other sizes (A59076)
LOT: (9) Tires &...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A56435)
2021 John Deere...
24017 (A56859)
24017 (A56859)
