ford 3000 question
   / ford 3000 question #1
bab288
Central, Ky
1969 Ford 3000, 2007 Simplicity Legacy XL 4X4 FEL
Just confirming that #1 cylinder is front of tractor, closet to radiator
   / ford 3000 question #3
I have a 1966 Ford 3000 and nothing on the instrument cluster works/lights up! Where do I begin?
Check the ground to make sure it is tight and has good contact to clean metal. There is a 3 amp fuse between the key switch and the voltage stabilizer. It could also be the voltage stabilizer. Hope this helps
   / ford 3000 question #5
deffinately do check the fuse aft of the cluster... post back..
until you do get it fixed, wire a low wattage lamp from switched power to the oil sender.. switch on, lamp on, engine not running.. engine running lamp off, if you have oil pressure.
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
2014 Peterbilt 384 T/A Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
Year: 2015 Make: Crane Carrier Co. Model: Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Vehicle Type: Truck (A51692)
Year: 2015 Make...
2014 Volkswagen Passat Sedan (A50324)
2014 Volkswagen...
