ford 3000 question
/ ford 3000 question #1
bab288
Central, Ky
1969 Ford 3000, 2007 Simplicity Legacy XL 4X4 FEL
Just confirming that #1 cylinder is front of tractor, closet to radiator
/ ford 3000 question #3
I have a 1966 Ford 3000 and nothing on the instrument cluster works/lights up! Where do I begin?
Check the ground to make sure it is tight and has good contact to clean metal. There is a 3 amp fuse between the key switch and the voltage stabilizer. It could also be the voltage stabilizer. Hope this helps
/ ford 3000 question #5
deffinately do check the fuse aft of the cluster... post back..
until you do get it fixed, wire a low wattage lamp from switched power to the oil sender.. switch on, lamp on, engine not running.. engine running lamp off, if you have oil pressure.
