Ford 3000 hydraulic problem
/ Ford 3000 hydraulic problem #2
With the Draft/Position Control lever set in the Draft (downward) position, engine running, lower links full down, stand on the lower links, pick up the upper link and push it forward to compress the draft control spring. If nothing happens, you have a control valve issue. If the lower links raise, you should be good, or you have a control lever linkage issue.
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2015 Caterpillar 308E (A64126)
2015 Caterpillar...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2006 Dodge Ram 1500 Pickup Truck (A61568)
2006 Dodge Ram...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
